i need something to do today an i keep reading about everyone removing this ringOo..... how do u remove it? do it myself or have shop do it?
It is a do it yourself project. It is located in the tube that goes between the air filter and the turbo. I have not personally removed mine because it is there to reduce the noise from the turbo (Whine)
and I am trying to keep mine quiet. Can't be too hard though, it you get it off more than likely it will be easy to see just how it comes apart.
Good Luck !
we are talking about the plastic piece inside the elbow bewtween the air box and the turbo right? mine had no snapring. just had to jimmy it out of the elbow. made very little diff... ... ... but i then got that powercoated pipe from genoes to replace the vain intake thing... . now it sounds better
Will this free up air flow? or is it just a noise maker?
Thanks, I did remove it and i hear a little more turbo, (also have a 5" from the down pipe back). I did notice in the air intake a x shaped baffle, whats that for? I am guessing to steady the air flow into the turbo. ? Just trying to get better fuel mileage without breaking the bank. Thanks everyone for the input.
