Simple Green
I think I figured it out......again
The Little Things
My last duty station was VF-41 in Oceana, VA. As the MMCO, I was in charge of all maintenance actions both good and bad. It turned out that our line division was using simple green when washing the A/C every fourteen days. Well the aircraft looked great, but the aluminum was starting to pit quite badly. Of course this was found by the annual inspection by fighter-wing... not good. Simple green does eat aluminum!!!
2000 24V, 6-speed, Flame Red, Agate leather, 3500 QC, 4X4, SLT+, 4:10's, LSD, AMSOIL Air/Oil filters and all Fluids, 275 RV squirters, S. S. nerf bars, Line-x, Autometer Ultralites Pyro/Boost/Fuel Press gauges, MOPAR tow hooks.
What about Super Clean from Castrol?
Rick
RICK
97 2500,CC,5 SPEED, 3. 54 Limited Slip,Psychotty System,K&N, Pre-Turbo ISSPRO 3" Pyrometer & Boost Guage,Silencer Ring Removed
15,000 RBW 5th Wheel Hitch,25' Excel 5th Wheel,Rancho RSX17000 Shocks,Amsoil Dealer,Straight Piped
Rick, Super Clean may be even worse on aluminum, but they have a new formulation that is labeled safe for aluminum, it's best to look for it and use. The only time I've had trouble with the old formulation on aluminum is if it isn't rinsed immediately, then it will cause spotting. Super Clean is also tough on some types of paint if left on too long, I've never had trouble on a car or truck paint job, but on a John Deere tractor the rinse water comes off green.
Hey guys I ran across this article about Simple Green. It seems that our boys in blue from the Air Force are told to not use Simple Green because of its corrosivness to aluminium. A study put a 3. 5 gram piece of aircraft grade aluminium in Simple Green for 7 days and it was reduced by 295 mgrams. Now I know this isn't much but we don't have high grade aluminium parts on our beloved cummins.
Steve
Steve
99 2500 Quadcab 4x4, PE Box, 275's, E-Brake, 4" Exh and 33x12. 50 BFG's
I love simple green; works great. What someone else said -- rinse well. No problems. ps: It takes stains out of carpet too.
I washed my engine with simple green a couple of weeks ago. Now I am going to rise again to make sure I got it all off. It sure did clean it though.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
It sure does make cleaning bug residue from the front of vechicles easy,spray on and let it work for 2-3 minutes and wash and they come right off I use it on chrome,glass and plastic,not on paint. JMHO
[This message has been edited by ramman (edited 04-15-2001). ]
I agree the citrus solvent is good stuff, but it isn't expensive if you buy it right. I pay $80 for a 5 gallon pail of 100% pure, a gallon is around $20. Buy it from an agricultural supplier under the name D-Limomoline, it is used in sprays. Be careful of the 100% pure though, it will dry your skin so badly that it cracks and bleeds if you get it on you. Mixes good with water. Best thing I've found for removing tar and gummy labels.
Eric, found out that what I am using is much more expensive because it is registered as a pesticide. Here is a source for $42. 62 for a five gallon bucket of D-limonene. I'll bet if you look around more you will find it closer to avoid shipping(about 40 pounds), and maybe even cheaper. When you buy it as a cleaner it is a total rip-off, this is exactly the same thing, but more concentrated, be careful.
[This message has been edited by illflem (edited 04-18-2001). ]
I used to use simple green to wash my dirt bikes, until I relized it was removing that new shine. But then I discovered mop and glow could put that new shine back on!
