I installed this kit with the slight modification of inserting a regulator between the filter and the VP. The kit went in fine with all parts being high quality, the fittings were smooth, and the hose lengths were perfect. My setup included a 2nd pusher pump mounted on the frame, the LP wire harness fit great, and the wire lengths were long enough to provide mounting options for the relay. To ice the cake, all plumbing and wire connections were labeled.
A word of advice... . Don't end the night without tightening the plumbing connections. Or, don't start your day without first finishing where you left off the night before.
If your really really fortunate, a friend will be there to check for leaks when you bump the starter
