It wasn't too bad to get to. I took that part of the dash off and got it out of the truck. I ran a hole saw through a thin piece of wood first, then C clamped it to the desired spot and ran the saw through again. There is a bit of plastic to trim behind the panel for clearance (no metal to cut), but it was very minor. I used a dremel with a small round wheel for this. I got power for the pyro's control box from the former lighter wiring, and mounted the box with a zip tie to the metal panel behind the knee blocker.
