Second try to post this , Found the gear set a dealer in Ind ,replaced gears . Slide will move in but will not stop motor when all way in , motor will blow fuse if direction is switched . Normal when switch is pushed slide moves from stop in one direction and if switch is pressed slide stops if switch is pushed again slide should switch directions . Mine in stead of switch of direction it just blows fuse. There is a adjustment that could be made according to the book that came with the trailer its located under the fridge . way in the back the adjustment wheel looks like a red knob with a white center with a slot small in center Arrow on cover shows direction to max or min. Any one know of this adjustment ,and is this the correct adjustment knob . This is a used trailer and I have never had to adjust the slide at all . The book that came with the trailer don't say much in the way of fixing any problems . Hope some one knows and will help me out . Thanks for any help . Ron in Metro Louisville KY
