Have you thought ,what will I do if the slide will not slide (in or out) . Well look in your book if you still have one ,and while still at a place that you can get help ,like home . See if you have the tool ,and know how to get the slide in or out ,without power and put it in travel mode with out having it not pulled in all the way or stuck , I found that mine will go in but that it is not flush as the shaft that turns it on the motor when not cuppled to shaft (manual ) method, is too offset , lets back side go all way in to stop while front will have one inch gap . Turned motor on after locking it back in and sent slid out some then back in put slide all the way in . Salution will weld eye bolt to frame center of slid and one on frame and use ,come-along or small chane hoist to pull slide all way in even . Just thought that some one could use this info for a start on there what if . LOL RON IN LOUISVILLE KY:-{} Oo.
