Engine/Transmission (1994 - 1998) Sliding the plate forward...
Hello fellow members! My name is Scott and I have been a lurker for a long time. I need a little help with sliding the plate forward. I have seen it referred to a million times, but I am not too sure how to do it. If anyone has any detailed instruction or a link to a site that provides them, I sure would appreciate it. I have been a big block hot rodder for years, but when I bought my 98 2500 in June of last year, I was changed forever. I love this thing. Also, I am looking forward to meeting some of the other local members on Thursday evening in the Antelope Valley. Thanks for your help.
Gung Ho Friends,
Scott
Since I have yet to set up a signature here is what I have. 98, five speed, straight piped and stock from there. Now comes the fun stuff... ...
Welcome aboard Scott.
Start here on the TST web site instructions for a plate install.
When you get to step 12 stop.
I had better luck drilling out the tamper screws to 7/64" and driving a T-20 tip into the hole and then removing the screw.
Continue
When you get to step 17 stop.
Scribe a line to reference the current position of your plate. Loosen the two big screws, slide it forward (1/16"?) and re-tighten the screws.
Follows the step to reassemble.
A 98 12 valve 5 speed. You should have a few droolers. Many consider this the best ever CTD RAM.
Welcome
Welcome to the club Scott. I am sure when you go to your local meeting the others will be glad to enlighten you on how to slide your plate or install one of the after market plates. I is realativly simple to do. It is easy to explain in person but takes up alot of space to give detailed instructions here.
Slide away & enjoy the free power. ;)
Wow! Thanks for the welcoming and quick responses. I wonder if I might be better off waiting and purchasing a cam plate since I am going to have it all apart anyway. Does sliding the forward stock have that great of an effect or would installing a performance plate give me a huge effect.
Thanks again for your help.
Gung Ho Friends.
Scott
Gung Ho Friends.
Scott
Numbers range from 40 to 60HP gain with sliding the plate forward. Those are all "heard" #'s not dyno #'s.
I've read it here many times before and believe it to be some of the best advice for getting started with power increases. Get your gauges. At the very least a EGT (pyrometer) and boost. Lots of nice ones to choose from. Have fun bombing.
not to change the subject but, i have a dyno at my shop and i strait piped the truck,k&n and slid the plate and it dynoed at 296hp@2500rpm:eek: what an increase. Ya thinkOo.
