Just returned from St. Louis. The problem got worse during the trip. Additive didn't solve the problem. While I was up there, I cranked up one evening and while I was waiting to get out of my parking space, the engine sound kept oscillating between normal and the sound you get when the EGR is cycling. Suddenly the engine stalled but didn't quit before it came back to life. Scared the devil out of me. Idle returned to normal. As I pulled out on the service road the engine suddenly dropped to idle and I had no throttle control. I coasted off the road and again the engine came back to life.
Today, I took it to the dealer. No codes and, of course, the problem could not be duplicated. I've known the mechanic for 14 years and he knows I don't bring in my truck for minor stuff. After we talked for a while, he said the dying was a symptom of a failing EGR. He is thing that it is intermittent as the EGR is cycling and not opening all the way when it should. Tomorrow the new EGR and a couple of other parts are going in.
I will keep this post updated as to whether or not this is the fix. It did seem a lot worse in cold weather so hopefully he is on to the problem.
Almost forgot, he did a flash update that was the full meal deal. Apparently, the have been several updates to the software, one of which solves this bucking problem. I could tell after the flash, that the acceleration was smoother and a little more torquey starting off.
I guess I will know tomorrow if the EGR is the culprit.
