You aren't gonna believe this one. After the throttle body was replaced the truck drove fine for about a week and the bucking/missing came back. The truck went in the shop for three weeks and they replaced three injectors that had some carbon. The other three were in excellent condition. The truck continued to buck and shudder and it felt like it was missing. It was very noticeable at temps above 50 degrees.
After opening a Star case, the dealer broke three appointments to take the truck back in. Angry doesn't begin to describe what I was on the last trip in when they told me I needed to get a second opinion on the problem. The truck was down on power, sometimes hesitating when I pressed the accelerator. Mileage was down about three mpg on the highway and worse around town.
I called Ram Customer Care and they reviewed everything and suggested I take it to the dealership in Perry, GA. They were very helpful and opened a case number for me. I had to wait four days for an appointment but it was well worth it. At the dealership, the service manager wrote down everthing I told him. Then he had me talk to the mechanic and he wrote down a bunch of notes. We took it for a ride and he felt the missing/bucking as soon as the truck started to shift gears.
Two hours after I dropped the truck, the service manager called. Here's what you won't believe. It was the fan clutch. The clutch was engaging and disengaging putting significant noise on the engine load signal line to the ECM. The noise was causing the problems with the load signal. When I looked at it on the data download, it would be a flat line that suddenly went crazy with noise spikes. Then it would go back to a flat line like it was supposed to. Althought the fan clutch was not under warranty, the dealership replace it for no cost because I had so many problems at the other dealership. I tipped the mechanic and gave them a great write up on the survey.
The next morning, I picked up my truck with the new fan clutch installed and she runs like a sewing machine. Althought the fan clutch was not under warranty, the dealership replace it for no cost because I had so many problems at the other dealership. I tipped the mechanic and gave them a great write up on the survey.
Mileage on the highway is up to 20. 5 and around town my EVIC is showing 18. 5 this week. When I took it in, it was showing 14. 7 and it is usually pretty accurate.
I will not go to the Warner Robins, GA dealership again if I have any other option.
