2nd Gen Non-Engine/Transmission Sloppy drive train
Engine/Transmission (1998.5 - 2002) AEM Brute Force Intake
Engine/Transmission (1994 - 1998) 230 horse P7100
I have a '99 24 valve 4x4 short bed (125,000) with noticeable slop in the drive train. Clunks when I put is in gear and clunks when I let off the gas. U-joints are good. Transmission is a DTT in good shape. Rear end is tight. Problem goes away when I shift to 4x4. The only thing left, I far as I can tell is the transfer case. Anyone have any ideas? Anyway to confirm transfer case?
Spring wrap?
Check your rear spring bushings and perches?
Short bed?
Do you have 2 rear driveshafts?
If yes? check the driveshaft carrier bearing.
SFB
Check the splines between the shafts too. If it's the T-case, it would be wear between what's connecting the input and output shafts. I don't remember the arrangement, it's been a while since I've been inside one.
