Engine/Transmission (1994 - 1998) Smallest Twins setup.
Engine/Transmission (1994 - 1998) A/c Line Removal
Engine/Transmission (1994 - 1998) First Time CTD Owner
Ok, just piped in boost from the intake manifod to the old wastegate out on the AFC with 1/4in hose. Its getting boost to the AFC now. but still not able to get over 30-32 psi boost. I think I just need a little more fuel to drive the ole' Super B. Need to get a clutch and a transmission first though.
Now back to my original question. What is the smallest twins setup for this engine. What would be the lowest HP that twins would require. :cool:. I am looking for more fuel economy and reliable EGT's
I thought I'd post a little info on towing and twins. My brother and I both have fords with 96 cummins in them, zf-6 speeds, and SB Clutches. I have a 215 pump and my brothers is a 175. We both have the PDR setup of towing twins. He is probably around 400 hp and I'm not sure where I'm at(maybe close to 500?). We both pull quit often and so far there has been no egt issues and spool up is great on both setups. One you hit about 10 psi, spool up is instant. Mine will get to peak boost faster, but that is because of my fueling. Altitude is aroud 5500 to 7000 almost all of the time and I have pulled a load through passes of around 11,000 and never had problems.
From what I have read and done, I believe the 35/3b setup is about as good as it gets for towing and reliability.
