Dave, There was a schematic that showed how to bypass the signal around the ECM to the PCM on one of the transmission sites. I can't find it now but I think there may be a way to use this for an upgrade.
If the signal was intercepted from the APPS and run thru a voltage converter, AGM, Phenoix or Weidmuiller, say 0-5 vdc to 0-10 vdc. This signal would then give a greater APPS voltage to the PCM for shift ranges. The Smarty would see the same signal but the PCM would see a different value. The converters are only a c-note or so. If you like I could get the part #s and post them for you. Mike
That would be very interesting!!
If you could pass on that info I would greatly appreciate it!
Dave
