Engine/Transmission (1998.5 - 2002) smarty/comp, smarty/adrenaline, adrenaline only?
Engine/Transmission (1998.5 - 2002) EDGE Products
2nd Gen Non-Engine/Transmission Heat Shield For BHAF
Got the smarty/comp setup now, but there seems to be a lot of hype about the adrenaline now. Should i ditch the comp for an adrenaline? or should i ditch both the smarty and comp? I really like the smarty especially with the new downloads. I am also happy with the comp, so if the difference is minimal, i'm not sure i want to make the change? anyone with experience with these combos?
Adrenaline has a lot of different things you can do, such as turbo timer, different programs. IMO they are gimmicks it doesn't really make any more power than you smarty/comp stack. I really think you'll be spending alot of money for very small return.
The plus with the Adrenaline is that it can be changed on the fly which would be fantastic. I'm interested to see what the smarty/adrenaline stack does, I may dump the comp if it looks promising. If its not much better combo than the smarty comp i'll just keep it.
I really like the smarty every since its been out but programming for fuel economy, not being able to switch to kill the stray ford on a moments notice and reprogramming the theft deterant every night to keep my truck from going to Mexico is a PITA. If the adrenaline/smarty could make a better adjustable stack it sure would be nice.
