SMARTY Made it through AZ Emissions Testing
Caution Consumers
lock-n-stitch
This was the first year I had to do the annual emission test on my Cummins. Not wanting a bunch of smoke, I loaded the #0 software and drove it to the testing station. The measured Opacity was 6. 1 on a limit of 30. 0
In AZ they put you on the rollers and you have to get the speed up to 47-53 MPH in any gear you want. I used 4th gear and created quite a racket in the testing building. I could see employees covering their ears while I was running. :)
SW #0 WORKS!! Oo.
Mick
I am so glad we do not have to do that here in Texas ... YET! . . I am sure there will come a day though.
For diesels here in Texas you pay your $10, they check the safety items (horn, lights, wipers, brakes etc) and slap the new sticker on and away you go :)
Kevin
On rollers huh. That is interesting since I just did mine a month ago and it was the 6 snap test, no rollers. I wonder what that is about. Reading was 0 opacity and allowed 40. Of course that was with the box off and 3/4 throttle.
Dave
if you got a 6. 1 and 30 was the limit you should have cranked it up just to see what it would do! I'm sure the guy testing it would have been impressed. :-laf Tell him you thought the rollers were a dyno!
:-laf :-laf :-laf :-laf
I don't think those guy's have that kind of humor. When I pulled in they donned their masks. I asked the attendant if it was that bad with a diesel. He replied that they are told to wear the masks because of cancer concerns with diesel vehicles :rolleyes:
Dave
:--) I can just imagine what they'd do if I said "hold on a minute, I need to change the programming in my ECM to make some power" Probably call the Air Quality folks on me and I'd NEVER get a renewal for the registration EVER again. :D :D
I can make REAL smoke on anything above#1 ;)
Mick
Here in NV. the test is on the rollers and the only way you don't pass is to fail the visual. My friend and I went in to see who could fail first. I had a Bell Usb turbo 130hp injectors and comp set to kill and could only blow a 3. The test is a joke. I can blackout the freeway if I want. I still go in with my mach 6's,comp on and the twins and blow a 3. In Nv they have a # to call to report a smoking vehicle and the advertise it on billboards as a license plate and it says 686smog. I have that same plate on my truck. I could not believe they sent it to me.
TJ
1/2 hp on vp 44 trucks an now cr trucks turn 700 hp into a nice 350 hp daily driver.
I heard this from a lot of customers 24v valet switch :-laf
