I read somewhere that the upper levels will exceed the capabilities of my stock turbo. What does that mean? Also in the adjustable options it is not recommended to run Rail pressure on level 3 or 4 for extended periods. What is considered an "extended period of time"? Timing level 3 is for aftermarket injectors. What happens if I run this setting with stock injectors?
Thanks,
Drew
Thanks,
Drew
