Smarty S-06 PoD
WTB 2nd gen Cummins 4x4 auto shortbed ext cab 12 V
2017 dually bed. Bed, bumper and tail gate.
Phillipjon
Used, and UNLOCKED comes with Tuner, OBDII cable, USB cable, manual, case. Everything is in excellent physical and working condition.
This unit is for 03 - 07 5.9 Dodge Ram Cummins turbo diesel only. 450.00 Shipped to your door
Fast guide to Smarty's special Features
•CaTCHER software's inside
•Ten different performance levels.
•Fastest download in the industry, up to three times faster than the
competition, a typical ECM update takes about 3.5 to 5 minutes,
depending on the truck model.
•ABS tire height updates in just few seconds.
•Not traceable in the stock setting. Smarty leaves no footprint.
•Manual High Idle is enabled in all softwares
•Reads Diagnostic Trouble Codes in plain text.
•No tools required, no fuses to pull.
•USB built in for simple updates .
•Most complete keyboard in the industry.
•Reliable, it works off your OEM hardware.
•Programmable Speed Limiter from 25 to 250 mph
•Power on Demand
Fast guide to Smarty's software levels
The horsepower settings. except #0, all other softwares have a
modified "Torque management" ( TQM ). The throttle response is
greatly improved but is set to a safe limit. With "Safe" I mean safe for
your transmission and rest of the driveline.
•SW # 0 : Half power
•SW # 1 : 30 hp increase, with added timing .
•SW # 2 : 60 hp increase, no added timing.
•SW # 3 : 60 hp increase, with added timing.
•SW # 4 : 90 hp increase, no added timing.
•SW # 5 : 90 hp increase, with added timing.
•SW # 6 : 160 hp increase, no added timing.
•SW # 7 : 160 hp increase, with added timing.
•SW # 8 : 210 hp increase, no added timing.
•SW # 9 : 210 hp increase, with added timing.
