1 of the First 100 Smarty's in this country, Still with the "ORIGINAL" Program!
ZOOM, ZOOM!:-laf
You'll be needn a 3-D torque converter and valve body, minimum.
With the above, TC and VB, I experienced a 30 HP increase, minimum and a 2 mpg increase.
Just say'n.
http://goerend.com/dodge/
Now I have Dave's FULL Build.............................dyno tested :--)
You can change the TQ management in the software of the Smarty program that you are using.
The following options are provided. #0-Default #1-OEM Stock Torque Management #2-Mild #3 Moderate (after market clutch/AT transmission recommended!) #4- Wild (after market clutch/AT transmission needed!)
Per MAD'S the higher the # you choose the less Torque management remains and more aggressive the throttle response becomes.
Good Luck!
