Smarty Speed Limiter
Exhaust Gas Temperature--Shutdown
I see MADS now has a new update for Smarty. A programmable speed limiter. !!:D:D:D My update is downloading right now!! Cant wait to see how it works. Any info on how it will be programmed??
Dane
For some reason i can't get mine to download. Is there a special program you have to have to download the newer updates. THanks
Well, Ive had mine on my truck for two days. Lost my key count, but they fixed the bug so you shouldnt. Also, my truck shakes at 110-115, but I couldnt get it to do it today (not sure what the shake is from). Hit 120 comin home from work. Its adjustable from 5-200mph...
No there isnt a special program.
ON EDIT: Its adjustable from 25-250mph...
Yep works for me too.
Last few times I've run over 108 with just the EDGE I needed to "key forward" to disable the ABS. That's a little un-safe as you to have to take a hand of the wheel and at that speed, 2 hands is nice.
I've run 3300rpm (ez helping out?) and calculated 117mph. The first day with the Smarty I seen 120 on the "record" on the edge box and 3400 and some change in the RPM.
It was a good feeling to finally get that speedo needle to the other side.
Time to air up the rear tires a little (45psi for traction) so they are a little more stable at the higher speeds.
Another trick that works is to calibrate speedo for smaller tires... ... ... 128 on the gps.
professional driver on closed course etc... ... ... ... ... . :-laf
Bob
Bob
Yep, that would work. prior to the smarty, I had no method to re-program with out hte cost of $50-120 to a dealership.
Is the update also available for us 2nd genners? I'm tired of losing out on top end to pesky Duramaxes, and that's with my 3. 54 gears...
