Yep works for me too.
Last few times I've run over 108 with just the EDGE I needed to "key forward" to disable the ABS. That's a little un-safe as you to have to take a hand of the wheel and at that speed, 2 hands is nice.
I've run 3300rpm (ez helping out?) and calculated 117mph. The first day with the Smarty I seen 120 on the "record" on the edge box and 3400 and some change in the RPM.
It was a good feeling to finally get that speedo needle to the other side.
Time to air up the rear tires a little (45psi for traction) so they are a little more stable at the higher speeds.
