This definitely occurs only with the smarty program in the ECU.
1st gear, engine cold/cool, it will miss similar to what blue chip describes as the failing VP44/map sensor situation.
Could this be a marginal MAP sensor and the smarty program is more sensitive to it?
This is a nearly brand new Blue Chip pump, MAP sensor has been cleaned... I'm also at 4200ft-ish elevation.
I love the way the Smarty performs, except for this. It is VERY annoying.
