Engine/Transmission (1998.5 - 2002) Smarty + ???
Engine/Transmission (1994 - 1998) Oil sample- high lead
2nd Gen Non-Engine/Transmission Help with guages!
That would be the hot ticket... I have a customer that is running an Edge Juice and a Smarty... all it has been is :mad::mad::mad:#@$%!#@$%!#@$%!. .
If it were not for the attitude monitor I would pull the edge out and replace it with the TST box. .
Rick
Smarty +???
Not a lot of people like Banks stuff, but I have a stage 5 combined with a smarty and its worked great for me... no problems(Smarty on even number and haven't had issues with high egts when pulling)
I also have a Big Hoss #5 and it works great with the Smarty. Timing from the SMARTY on odd numbers and fuel from the Banks.
John
So are you guys running the Smarty on the odd #'s with timing and the TST for fuel only? Has that been giving you the best power?
Randy
Randy
Actually, that's pretty much the idea. The TST is good for fuel only anyway-no timing. The Smarty adds some fuel too, but brings the thottle response in much quicker and the timing seems to lower egts a bit, though not a huge amount. Even though the two were made by different companies, they see as if they were made on purpose to work together. A great combination.
Alright, thanks. I've been trying it the other way. I'll have to see how it runs with the Smarty timing.
Which is fuel only, the power or torque #?
Randy
I use the Smarty with the Blue Chip FMS and love the combo. One little button push away from the good stuff. I have never used the TST or ridden in a truck with it, but it seems to be extremely popular as well.
i know someone said they didnt like it with the edge box how come. Anyone out there running the smarty with the edge programmer i wanna order a smarty :D
I have no dyno results to back this up, but the butt-o-meter tells me that #7Smarty/#5TST is a great combo for quick throttle response and big pull up top. I have tried #9Smarty/#5TST, but throttle response a little TOO abrupt. I can't go past #5 on TST until I get a new turbo because my EGT gauge wraps around as fast as the tach does.
Tim
