Smelly Cab
Which injection pump do I have? Help
Trans. Temp. sensor location?
Hi guys, My new Dodge has a Cat Pee smell as soon as I start it the next day? What is this from??? I want to smell "NEW", not this other stuff... ... .
Thanks for any insight.
WHITE,01,SLT,4X,QC,CUMMINS,SWB,AUTO,4. 10 LIMITED-SLIP,CAMPER GRP,TOW GRP,KEYLESS ENTRY,ABS,ALL DISC ETC,ETC.....
OTHER TOY: FORD GT-40 REPLICA, (ONLY ONE LEGAL IN US. )P le Blanc
I've had this problem with my last car. Dam cat was jumping on the hood, and marking the windshield as his "territory".
I used a Marlin lever action, and 22 shorts. Quite effective. Very quiet too.
This didnt kill him. Too weak of a cartridge. It dam for sure made him remember DONT GO THERE!!!
This might not be an option for you if you have neighbors close to you.
Eric
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 265 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
[This message has been edited by The patriot (edited 05-08-2001). ]
Thanks Patriot... ...
I,ve got a 7MM Mag for these purposes, but there are no cats around. This smell is very short term and seems to be related to the Airco. So if you've got any other ideas???
Thanks EMD, I don't think this is as simple as that... ... Someone e-mailed me that D/C has a tsb on this issue and it is covered under 3/36 warranty. It's "Mold Spores" on the evaporator.
A good home remedy is to spray Lysol into the cowling air intake. This will kill mold ect. the stuff DC uses is basically the same.
Rich
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,Camper pkg,354 LSD rear axle,Raven Magnum 8' cap. Mag Hitech trans pan. Isspro gauges pyro,trans and boost Apillar mount. Amsoil air filter. No muff!EZ Edge!!!! N. R. A. member
Had the same problem last summer when first starting the truck. I used a large can of Lysol, spraying it in the windshield cowling before and after each trip.
Smell still there. I read a post from the TDR that suggested turning the air selection switch to VENT. Run in this position for several miles (before your destination)to dry the evaporator out. Since doing this I haven't smelled the musty smell.
I extended the drain tube from the air conditioning condenser. It solved the cat pee smell. It's located behind the AC expansion tank on the passenger firewall and I used a 5/8 elbo, a hose clamp, and 2 feet of 5/8 tubing and ty wraped the end of the tube to the frame.
By extending the tube into the slip stream you create a veturi effect and draw the condensate from the condenser and eliminate the smell.
-Paul R. Haller-
Adding to what's been said, Try turning the A/C off a few minutes before your destination. Condensation builds up inside the duct work and creates mold. By allowing just the fan to run for a few minutes, it removes quite a bit of it. Works for me.
98. 5' Emerald Green 24v 2500 Auto/3. 54 4x4 SB QC 285. 75. 16's Bridgestone Dueler A/T's on 16" x 8" Alcoa's under Rancho 9000's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk).
Thanks for all the input guys! It's appreciated. I think I'll go with Paul's solution... ... Being a design engineer myself, it seems to me that introducing a negative pressure in the drain tube is a solid technical solution to stagnant water in the evaporator. I'll let you know what happens...
In the mean time it's "Bombs" away with Linex bed liner and Grizzly "Double Bend" nerf bars.
Another solution is to use Recirc over regular AC. Recirc has a lot of advantages in that it does not constantly reintroduce hot outside air into the system (less work for the compressor, condenser, and evaporator), thus reducing the engine load and saving a bit of fuel. Recirc also does not have the moisture problems that normal AC does, since it is using the already-dehumidified cool air. Also, Recirc AC cuts down on the system taking in diesel fumes from the engine compartment if you have passengers sensitive to that.
At least once a month in spring and summer, I "fog" the interior with Lysol (the Crisp Linen scent is terrific), and allow the AC to suck it in through the air return ducts for a few minutes before shutting down. makes everything smell fresh in the interior, and keeps an amount of the antibacterial ingredients in the ductwork until I come back.
1996 3500 Club 4x4 Laramie SLT, unmodified 180/420 12-valve, 47RE automatic, 3. 54 limited slip
[This message has been edited by KCJackson (edited 05-11-2001). ]
I'm with what deezal man said, but I put it on vent and the fan on high about a mile from the house.
I've also put citrus solvent down the cowling. (love that smell!)
Eric
Well, if all else fails you could tap into the smoke pipe, say 1/4 NPT fitting and pipe it directly into the A/C ducting. Probably kill all the mold/fungus/bacteria and make a great air freshener to boot #ad
This idea should not be tried at home, only by professionals on a closed course...
Kurt Voss
********* 1999 2500 24VCTD AUTO 4x4 QC LB Laramie SLT, Luverne stainless steel nerf bars, 3 piece bug deflector, mopar mud flaps, Line-X bedliner, Blue Chip Fuel Management System (Premium), Psychotty Air, DD3's,TTPM, DD 4" exhaust, HX40, DTT VB/TC(91%) , Mag-Hytec transmission pan... YEEEEEHAAAA!!
2000 4x4 Z71 Tahoe, all options, rear AC, brush guard, nerf bars, mobile video system, after market 3rd row seat... the ultimate urban assault vehicle!
