SMOG CHECK - Coming to California January 1, 2010; Coming to Your State Soon?
Had to share
FWIW! Pay Attention at the Diesel Pumps!!!
TDRadmin
Staff Member
Déjà Vu All Over Again, Again​
November 2009—the world of the automotive aftermarket has its annual gathering at the Specialty Equipment Manufacturers Association convention. Two years ago (Issue 60, page 50-52) I covered a meeting that was a part of the 2007 SEMA Show with EPA representatives, California Air Resource Board (CARB) personnel, aftermarket vendors and SEMA liaisons.
The topic of discussion in November 2007: What is the process (test procedure) that aftermarket vendors should use to submit their products for CARB testing, approval and the resulting emissions stamp-of-approval which is known as a CARB executive order (EO number)?
The topic of discussion in November 2009: You guessed it, the same thing.
In preparation for this article I went back to Issue 60 and reread the text. In the past two years a lot has happened, but nothing has changed. A lot has happened: the CARB folks and the aftermarket were on the verge of a testing protocol until the question of how tuning programmers would affect the truck's auxiliary emission control devices (AECDs). Take one step forward and two steps back. Should you want to read the assorted details, the Issue 60 text is still relevant. My impression: It is almost like the stalemate of not having a test procedure was/is wanted by the CARB personnel.
SEMA liaisons have been to this dog-and-pony show before. Need examples: look at all the chips, programmers, intake manifolds, camshafts, fuel systems parts, etc. , that exist with CARB EO numbers in the aftermarket for gasoline engines. But, they've not been able to get the diesel players (CARB and vendors) onto the same page.
Aftermarket vendors seemed concerned, but internal bickering about how the test procedure should work is still a point of contention.
Again, the CARB personnel did not seem to care ‘cause they're gonna do what they're gonna do. And—oops it is like you are back in high school again; the term paper now has a due date, January 1, 2010.
That's right folks; the state of California, through the emissions testing facilities at the Bureau of Automotive Repair (BAR) will require a diesel smog check effective January 1, 2010. Ouch.
So What! I Live in Texas (or any one of the other 50 states).​
You live in Texas. I am in Georgia. What does all of this emissions inspections stuff have to do with those outside the Republic of California?
The obvious answer (Does this question even need to be addressed?) is that what happens in California somehow happens in other states that follow their lead. If past history indicates future activity, look for the states of New York, Maine, Massachusetts and Vermont to follow California's lead. However, as you'll note in the quirks that are a part of California's inspection process (items 7a, 7b, and 7c), the diesel smog chick in your state may be better defined with less subjectivity. Time will tell.
Just the Facts, Please​
All right, just the facts:
California Diesel Smog Check
1. Required by Assembly Bill 1488 signed into law by Governor Schwarzenegger.
2. All 1998 and newer model-year diesel-powered vehicles 14,000 pounds or less GVWR are included.
3. Initial registration and change-of-ownership inspections begin January 1, 2010, and notification for biennial (every other year) inspections will begin in February/March for renewals due in April/May.
4. About 540,000 vehicles will be subject to Smog Check for initial registration, change-of-ownership, and biennial inspections in order to complete the registration process.
5. No “New Diesel Vehicle” exemptions will be allowed. Every truck gets tested.
6. No tailpipe emissions test will be required. (Sounds odd, doesn't it? See #7. )
7. The Diesel Smog Check Inspection consists of:
a. ) Visual Inspection for tampering (missing, modified or disconnected emission controls and the presence of parts without a “CARB EO Number. ”
b. ) On-board diagnostics (OBD) interrogation to check for proper MIL operation: the MIL commanded “On” or “Off”, and no more than two readiness monitors “Unset” or “Not-Completed. ”
c. ) Visual smoke inspection (modified snap-idle procedure) to determine if excessive smoke emissions are present.
Like me you're thinking, “Whoa! I need some details about the scope of the test. ”
Okay, I'll go through each line item and add clarification as I understand it.
1. Yes, it has been singed into law.
2. Yes, its target is light- and medium-duty diesel vehicles.
3. Every other year inspections.
4. They're going to test all 540,000 vehicles. They have a process.
5. In California when you purchase a new gasoline-powered vehicle you are exempt from testing for six years. The CARB folks have a history with gasoline vehicles and are confident that they remain clean for the six-year “new vehicle” period.
They do not have a history with diesels. They have seen some gross examples of pollution. Therefore new diesel vehicles are not exempt from the biennial smog check.
6. The smog check station will not do a “sniffer” into the tailpipe or use an opacity meter. Why? A government boondoggle. There is legislation in place that states that there cannot be additional capital equipment required at the 5,000+ smog check stations. Yet the Assembly Bill 1488 requires a smog check. The result, a subjective pass or fail inspection of hardware under the hood for the CARB EO number decal (see #7a). If you pass the inspection, then there is a subjective snap-idle test (see 7c) to determine the pass/fail.
7. a) Visual inspection, another boondoggle. The smog check station personnel are going to look at the components of your diesel engine in search of CARB EO number decals. No decal and they can send you home with a “failed” notice. The following chart will show you the parts/components where the inspector will look for the EO decal if the part does not have a factory appearance.
CONTINUED . . .
SMOG CHECK Continued
<HTML>
<p class="MsoNormal" align="center"><span><strong>Diesel Aftermarket Parts Quick Reference<br/><br/>
</strong></span>
<table border="1" cellspacing="2" cellpadding="2" width="80%"><tbody><tr><td><p align="center"><strong>System</strong></p></td><td><p align="center"><strong>Component</strong></p></td><td><p align="center"><strong><u>Allowed</u> as OE Replacement</strong></p></td><td><p align="center"><strong><u>No</u> CARB OE is Required</strong></p></td><td><p align="center"><strong><u>Requires</u> CARB OE</strong></p></td></tr><tr><td>Computer Management</td><td>Variable Or Alternate Tuning Devices: Power Modules, PROMs, Chips, Tuners, Pods, Power Modules Or Any Device That Modifies Inputs Or Outputs To The ECU (Including Inline Devices That Plug Into The ECU, Wiring Harness, Or The OBD Connector, Signal Conditioners, Etc. )</td><td>&nbsp;</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td></tr><tr><td>Induction System</td><td>Air Cleaners</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>"Air Horn" Intakes</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Intake Manifolds</td><td><p align="center">&nbsp;X<span><sup>1</sup></span></p></td><td>&nbsp;</td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Air Flow Sensor(Modifications)</td><td><p align="center">&nbsp;X<span><sup>1</sup></span></p></td><td>&nbsp;</td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>EGR/CDR System (Modifications)</td><td><p align="center">&nbsp;X<span><sup>1</sup></span></p></td><td>&nbsp;</td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Turbochargers (Add-On Or Modified Parts Including All Related Controls -&nbsp;i. e. Waste Gates, Compressors)</td><td><p align="center">&nbsp;X<span><sup>1</sup></span></p></td><td>&nbsp;</td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Intercoolers</td><td>&nbsp;</td><td>&nbsp;</td><td><p align="center">&bsp;X<sup>2</sup></p></td></tr><tr><td>&nbsp;</td><td>Supercharger</td><td><p align="center">&nbsp;X<span><sup>1</sup></span></p></td><td>&nbsp;</td><td>&nbsp;</td></tr><tr><td>Fuel System</td><td>Auxiliary Fuel Tank(s)</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Injectors</td><td><p align="center">&nbsp;X<span><sup>1</sup></span></p></td><td>&nbsp;</td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Injection Pump</td><td><p align="center">&nbsp;X<span><sup>1</sup></span></p></td><td>&nbsp;</td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Fuel Pump - Lift Pump</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Added Fuel Filters/Separators</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Added Or Alternative Fuel Modifications</td><td>&nbsp;</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td></tr><tr><td>&nbsp;</td><td>Added Or Alternative Injection Modifications Including: Propane, Methanol, Hydrogen, Nitrous Oxide</td><td>&nbsp;</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td></tr><tr><td>Exhaust System</td><td>Exhaust Gas After-Treatment Controls:&nbsp; CATs, Traps, Filters, UREA</td><td>&nbsp;</td><td><p align="center">&nbsp;N/A<sup>4</sup></p></td><td><p align="center">&nbsp;N/A<sup>4</sup></p></td></tr><tr><td>&nbsp;</td><td>General Exhaust System Changes For Vehicles Not Equipped With After-Treatment Emissions Systems (Must Have Provisions For Any Stock Sensors And/Or Emission Control Components)</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Exhaust System Changes:&nbsp; Changes After The Last Emission Control Component "CAT Back"</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr><tr><td>&nbsp;</td><td>Exhaust Brake Systems</td><td>&nbsp;</td><td><p align="center">&nbsp;X</p></td><td>&nbsp;</td></tr></tbody></table><br/></p>
</HTML>
For more details and the exhaustive list of equipment that causes a Smog Check failure, please reference Appendix G.
1 - Must be Replacements for the original equipment.
2 - Add-On and/or modified/performance versions must be CARB approved and require EO verification.
3 - These CARB EO rules only apply to the Smog Check program.
4 - Must meet OE standards.
Did you notice the X1 and X2 and the footnotes at the bottom of the chart? The visual inspection is, at best, subjective. So, since very few parts (if any - see “Noteworthy” below) have a CARB EO decal, I'm hoping that the California TDR audiences are good friends with the smog check operator; otherwise you will not have a chance to get an “at bat” with the snap idle test. Do you still have all of your stock parts in the garage?
7 b) The test operator plugs into your OBD II connection point the ABD II reader and can tell if a performance module/chip/programmer has been clearing and/or turning off fault codes.
7 c) If you passed the subjective visual inspection of item 7a then it is time for the subjective visual smoke test. The cynic in me learned in the meeting that the smog check inspectors have seen a video telling them how much smoke is too much smoke. Jeez… good luck. My understanding of the test: the engine is taken up to 2000rpm and “snapped” up to a 3000rpm threshold. The video-trained smog check inspector then issues the pass/fail.
CONTINUED . . .
On My Own/Noteworthy
I'm sure you noticed all of the X1 and X2 and solid Xs on the Aftermarket Parts Quick Reference chart. In those cases where there is a CARB EO “Required” you should check your aftermarket product for the appropriate number.
Wait, I'll save you from running to the garage to lift your truck's hood to look for the decal or making a dash to the file folder where you keep all of your records. You see, I reread the Issue 60 text closely and the hard, cold fact comes to you from page 52. Quoting from the article, “Noteworthy: from '03 to current there is a void in EO certificates issued due to lack of approved protocol of testing procedures. ”
Mr. Customer, reading between-the-lines it looks to me like you are on your own.
I could break-out another power-point chart showing the components that require strict emissions testing (again, the test protocol has not yet been determined), those that require a shuffle of paperwork called “engineering evaluation;” and those where there are “to be determined” and “need to resolve” notations. Suffice to say the aftermarket vendors do not yet have the CARB EO number decals and neither do you.
So, what are you to do as you and the smog check technician stand there and argue (or would that be subjectively review?) whether your turbocharger is “Allowed as OE Replacement (X1);” or is it a “Requires CARB EO (X2)?” It was suggested in the meeting that Mr. Customer have the smog check technician telephone the CARB representative, who then telephones the aftermarket vendor that made the component to discuss… Yeah, right, this ain't going to happen.
Mr. Customer you are on your own. I'll ask again, do you still have all of your stock parts in your garage?
Conclusion​
For this boondoggle I do not have a conclusion. For those on the TDR's web site we are posting this article in late November as a preview of things to come for our California members. The smog checks start in January for change-of-ownership vehicles and then in April for owners of record. I'll bring you updates as I have further information.
Robert Patton
Editor, TDR
YIKES! If they stick with the every two years method, it will not be that big of a deal to "uninstall" the download tuner. I could even come up with a way to quickly reinstall the CAT on my '96 and could detune it to be gutless where it will not smoke. Thankfully, the states you list are all socialist cesspool havens and are the same ones who have been buddying up with kaliphornia for years. Hopefully the rest of us are safe. GOD, I would HATE to have to live in kaliphornia or the other on the verge of bankruptcy places you listed.
Just curious, how the hell would the smoggers know if you had bigger injectors or a different cam installed? How would they know if you had made mechanical adjustments on a 12 valve engine? If it only has to pass "visual" inspection for smoke and presence of smog devices, that should be easy to fool for the inspections, then put back the way you like it for the next two years.
So the way I read this California will not test trucks build before 1998! Mine is a 1996 and does not smoke!
CARB EO number decals, SOON TO BE AVAILABLE
So... since the inspectors and aftermarket vendors do not have the "CARB EO number decals," why not just go to the local print shop and make some? In no time at all, the new nonexistant official stickers will be rejected by the inspectors because they have only seen the new Calif. eBAY label that will soon be available. :-laf
Great idea! See, there are ways around these things! Remember, these people are not the brightest bulbs on the tree anyway... they are government workers, after all and will not do anything more than required of them... . Hallowed out CAT, disabled EGR, high performance cam, bigger injectors..... tuning programmer installed, but removed for their inspection... They come up with a system, we find a way around it. :D
I just got my CA truck registration which is due in January, $597, and it doesn't show me needing the new smog test. I guess I'll have to wait until next year. I was hoping I could get it done now and then I'd have 2 years where I could take all the crap off. I've been running with the EGR disconnected and the mileage and performance is definitely better. The only thing I noticed is it seems to take longer to warm up now.
Just another idiotic law that Kalifornia has come up with. The state is bankrupt and they will do anything to increase the bite on the public! This will be another law that I will probably ignore if it ever comes to Ohio. Beautiful article that the TDR did tho. Moe
Well we new it was going to happen. Now we just come up with ways to get around all their BS. I just E-mailed Edge to see if they would build a box with out the power up-grades with a CARB number that I could plug the Attitude monitor into. This would allow me to still monitor my Diesel. The Smog Guy wouldn't have any thing to question about the egt probe and no gauge, and there would be less rush to hook The Juice back up after the Smog man. I could deal with that just like I changed Carburetors every two years on a Chevy.
Well,come April we'll see if Marco's tuner passes muster. The other area which might arise is forcing stock sound levels i. e. stock muffler. But as long as there are Harley's and Ninja's blowing me away everywhere,I think we're safe for the time being.
Edge and Banks would love to get a CARB# but there is no system in place for them to prove their worth. :{
Again, note: 1998 and newer diesel vehicles.
Plea for help: If inspections and test have already been initiated in New York and Colorado (other states?) I would like to see factual correspondence from those members about the procedure.
thanks in advance.
Regards, Robert Patton
thanks in advance.
In the state of Utah, there are currently 3 counties that require a smog test on Diesels, and they have been doing the testing for several years. They put the truck on a Dyno, and run it up to 50 MPH, then load the dyno so there is 50 percent load on the truck. They then read the level of pc10's and if you are in compliance for the year truck you have, your good to go, otherwise get it fixed.
All this will do is to cause people to swap their parts or tuner programs. There are those of us who will have the power adders and make sure we don't smoke excessively. I am not worried about the biannual checks, I am more worried about CHP spot checks. My truck is a 95 and is currently exempt. My 67 VW that I have had for 23 years was exempt, then the laws changed, it had to be tested again. Now it's exempt yet again. I don't hold out hope that the exemption rules will be permanent 'cause they can't seem to get their act together.
When you consider the improvement in air quality over the last few decades, I agree with the idea of smog checking, I just think that the state of CA has done a horrible job of its implementing it. A smog check should allow anything to be on the engine, if it fails the sniffer test, then it fails. If it passes the sniffer with the aftermarket equipment or tuner, then it should be allowed, period.
I have read that the smog check is for vehicles under 8501 lbs...
Plus... how the heck are you going to smog an engine that has an open crankcase from the factory, as my truck does... ??
Diesel-Powered Vehicles — Operative January 1, 2010
Amend, Repeal, and Add: Health & Safety Code §§44010. 5, 44011, 44012 (AB 1488 Chapter No. 739)
Adds diesel-powered vehicles manufactured after the 1997 model-year that have a gross vehicle weight rating of less than 8,501 pounds to be in the biennial smog check program.
$634. 00 in OC. No Smog. Probably happen in '13 for the '07.
YouTube - Bureau of Automotive Repair-Diesel Smog Check 2010
As far as Colorado goes we do have to get diesels inspected if you live in certain counties along the front range.
I cant say I know the exact procedure but they put it on a dyno get it up to a set speed. It only takes a couple minutes. The only thing they are concerned about is opacity. And I think upwards of 30% is allowed. They do not look for anything else. I have never even seen a hood get opened for this test. The price for an inspection for a diesel is upwards of $65. 00. There are a couple shops that offer it for 45. 00 but the going rate is 65. 00.
The one thing that sticks out in my mind in the OP's above material is that whether there is too much smoke is subjective and has no real criteria. I wouldnt doubt that with a court case that section gets thrown out as it is not a level playing field and is subjective and unmeasurable. However even if that part is stripped out the rest will still be a pain in the rear.
