Smoke Valet Switch?
Amsoil By-Pass Battery Bracket
HX40 Advantage?
I have noticed that some of you
have a "smoke valet switch" listed
in your signature. Is this a "joke"
or an actual accessory for our trucks?
If it is a "real" item can you explain
how it works.
I could definitely use some "help"
in controlling my smoke!
Thanks!
Red '96 4x4 2500 Auto 3. 54, TST #5, Major Pump Mods(By "Scheid Diesel") 370 Diamond B Injectors, Gov. Spring kit, AFC Spring kit, Banks Exhaust, Prime Loc, Cummins Chrome Kit, Pro-Torque Converter, BD Valve Body, BD Pressure Loc, Isspro Gauges, Sendel 16" Alum Wheels w/ 33" BFGs
John, Joe D. is the one that told me about this. It is an on-off electrical vacuum swicth that doesn't let the AFC move, making the cam on the AFC your torque plate when the vacuum is off.
It was a device I thought up a while ago. When I go to the airport & leave my truck at the park n fly lot they can move it to any one of three different parking lots after I leave it. I just didn't like the idea of some 17 year old car jockey taking my Ram for a joy ride. So switch on & they only have about 200hp to play with, switch off & I get get the 470 or whatever it is at the time to play with #ad
It blocks of the boost air thats going to the afc housing.
Piers, BD engine R&D
Piers,
Mike got the first batch of them and said "you've gotta put this on today" and I did and it was the best thing I've done for security of my truck next to the kill switches. No more worries about some idiot burning my clutch by driving like a dump truck driver.
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
drawson, Piers and Chris:
My sincere thanks to all of you for
the e-mails and explanations.
Piers, I will try to get a hold of
you in the next couple of days for
a price/order. Thanks. BTW... ... .
I sure am enjoying my "BD Diesel
Performance" jacket I won up at
the Scheid Rally especially since
the cold weather has set in here!
Thanks again to all of you!
John_P.
What do you guys think about the Valet switch helping when I try to pass the States Bi-Annual 20% Opacity (smoke) emmissions test.
The truck does not smoke much more than stock, But I`m getting nervous already.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 12-06-2000). ]
