Inside the housing you took off to get to the fuel plate, there is a little 'J' hook, take that off. Simply take out the small bolt at the end of the shaft, pull out the pin, remove the 'J' hook and re-install everything the way it was. MAKE FUEL PLATE STRAIGHT LIKE THIS ________________________________
