I have a smoke issue that came up suddenly. I'll do my best to describe the symptoms.
The truck is cold and the right mirror is positioned down so I can see the exhaust. With the transmission in L1 (so it doesn't shift) I'll depress the throttle about a quarter to a third and hold it there. (How much throttle doesn't seem to matter. ) A light haze is evident from the exhaust, which has been normal when it is cold. BUT,... when the engine reaches the RPM's equal to the amount of throttle, a heavy, solid, dense stream of blue/gray smoke pour's out from the exhaust. Now if I do either of one of two things it will quit. Either one being more fuel or let up on the throttle. This will continue but will be less and less until the engine is warmed up. What would the first thing come to mind if this was your vehicle? The vehicle is stock with about 204,000 miles on it.
