Snow kit help!
Oilguard bypass filter
Autometer pyro acting up
Ok, so I am trying to figure out the components of the kit and where things go. I figured that the silver fittings are for the injectors because they have threads inside and outside of the fittings but after looking at many install pictures here, it looks as though the 90* black plastic fittings house the injectors but there are not threads inside the black fittings. Furthermore, after looking at the threads inside the silver fittings, they are both buggered up (no I didn't try to do anything that may have caused this) so I thought that was more reinforcement that the injectores do not go in there. Uhhhhg, please help, I want to finally get this installed!
The compression style fitting are for the injectors. they are 1/8 pipe on the inside and 1/4 pipe on the outside. The 3/8 pipe fittings are for the pump inlet and outlet. Hope this helps you. Good Luck!
ok, (please excuse my drawing) so you're saying it needs to be plumbed like this?
I noticed most people are using the black fittings on the intake horn...
Red is the vinyl 1/4" tube
green is the existing tube to my boost gauge
yellow is the new rubber hose to the box
BPonci, would you mind if I called you also. I've had mine for awhile and haven't gotten around to installing it because of the same confussion of how it went together.
Pete
