Engine/Transmission (1998.5 - 2002) SNOW's water/methanol kit
2nd Gen Non-Engine/Transmission any ideas????
Engine/Transmission (1998.5 - 2002) I might buy a new truck.
Anyone running this kit wanna share some input on it seems like a sound idea but not sure it is benifitial for trucks that are not heavily fueled.
Running the stage 2 Kit with the Variable Controller. Runs Great with 50/50 Havn't used it yet for towing b/c i blew my headgasket. When it's on you can feel it kick in for sure. Take Fulmer's Advice and mine. Good kit, well put together and easy to install.
i don't run the kit, but i've heard plenty of times to keep it under 20% meth unless you have studs and superior HG. find member Winspeed for a couple of quickly blown HG!
I Heard Winspeed (Adam) Blew his 2nd HG because the Torque Specs That Came With the Arp Stud Kit Was Wrong. Otherwise Shouldn't of happened the 2nd time. But as far as running the stock headgasket and no studs yes i think beast is right keep the meth down and have the injection come in 10 psi before full boost 2nd at max. If you Tow I would Just have the 1st stage come on at 15 under Full Boost and max the stage 2 on the controller to boost you can't make that way the 2nd stage woun't come on. Heres a picture of what happened to my headgasket 52 pounds with 50/50 meth. #ad
