After 4 LP's on my 01, I relented and let them put the in tank in. I have had zero problems. Have about 40k on it now, some pulling a 34ft Montana 5 er.
WHAT SAY YOU?????
WHAT SAY YOU?????
The diaphram in the VP44 still is only good to flex . 5mm (about 3 psi) without dammage to the seals. So why is 1 psi ok?
Bob Weis
I am getting ready to replace a friends V44 because the intank pump did not flow enough and it trashed the pump. So from my perspective, it's not worth much.
WD
How many miles on the intank pump??
Was the VP44 replaced when the intank pump was installed???
steved
I've got 5k on my in tank pump and no problems yet. Of coarse I didn't care for the 8 psi at idle and 1 psi at wot so I installed a Carter 4600 (7psi) to boost the output to 15 psi at idle and 13 running down the road. We'll see how long this setup lasts.
