Engine/Transmission (1998.5 - 2002) So Just what is a po216 code any way
Engine/Transmission (1998.5 - 2002) how to improve shifting
2nd Gen Non-Engine/Transmission Ebay find
Houser here.
I dont know if any one has noticed but lately there have been a lot of VP failures with the po216 code. my truck included, with only 42k miles. and lots with even less. What does pump timing error actually mean? I talked a little bit about to the guys at Piers who told me that it wasn't actually the Vp part of the pump that was failing but the electronics or the internal pressure regulating stuff. When mine went the the failure was intermittent and became gradually worst over a period of about 8k miles. I believe that if the pump itself had actually failed it would have just lost pressure and failed, and not become an intermittent problem. my question to you guru's of diesel dynamic is what is actually failing in these pumps, and does it need to be 1500 dollar fix. Is there maybe just a sludge screen that needs cleaning or possibly a solinoid that can be replaced?
What do you think? What do you know?
Houser
Seems that this is an 02' problem child I also am seeing alot of the p0216 showing up on the low mile side. No stating its not in others... DH
My 01 also shows the p0216 also & has a surging at certain throttle positions. Ive also got a flat spot right off idle when my box is tuned on.
Kurt
The way I undestood the Cummins trouble shooting manual. The advance mechanism is controlled by an electric valve regulating low pressure fuel. The valve opens and the incoming fuel pressure actuates the advance system. The 0216 code is set when the VP44 senses that the pump is not advanced when it is supposed to be. This can be caused by lack of fue pressure from the lift pump or by failure of this valve to open when so ordered.
When mine went out it got extremely hard to start when hot.
