HHhuntitall,
Please feel free to be specific on the pinned barrel extension.
I was wondering how that system maintained headspace with no shoulder on the barrel.
How many rounds do you see, through a Lilja or Kreiger Barrel?
Accuracy?
Haven't heard to much from you, lately! You must be up to yer neck in alligators
Thanks, Brother!
Greg
Greg! They're only about knee deep, but I don't think they're alligators..... they're all floating around, but are brown and smell like politicians... :-laf It's been a fun month for me, been doing a lot of work, but also a lot of hunting. Lots of shell casings, dead pigs, and prairie poodles on the ground!!
The barrel extension is threaded on, as I'm sure you've found in your research..... the extension pin's index is dictated by barrel twist and the location of the gas port in the groove between the lands/riflings, as it has to be at the required length for the gas tube to fit and function. I don't have the measurements in my head, at the moment, but pistol is shorter than carbine, carbine shorter than rifle.... you understand, I'm sure. The threaded barrel threads into the extension, and you have to cut a shoulder on the barrel to fit against he face of the extension. Then you can measure an estimate of where you're gas port needs to be, and get it drilled. It's a tricky process to get it drilled in the groove, so I usually leave that up to the barrel mfg. I've screwed that up once, and it was a $300 lesson....
I don't have the tooling, myself. Once the barrel is drilled correctly, then you have your reference for the barrel extension pin, which has to be perfectly parallel to the gas port to align the gas tube with the receiver. I don't want to get into the gas port size here, but there are several sizes. Krieger uses a .093 gas port in their barrels. In fast twist barrels, 1:6.5 or 1:7, that may be a bit large, IMO. I've had to install adjustable gas tubes on several, as well as carrier weight systems.... It's not a concern if shooting DOD ammo, only with 80-90gr bullets, which I don't recommend for use in a magazine, anyway, but that's JMO.....
Anyway, with the gas port drilled, then you can index and tighten the barrel extension, taking off the calculated amount of metal from the front of the barrel and shoulder to get the extension in time with the gas port and bolt lugs, taking into account crush depth, of course.... Once measured out and torqued down, then you can drill the barrel for the pin and hammer it home!!
Once the pin is timed and drilled, it gets pretty easy, by comparison. You have to chamber off the bolt face, now, and I can't teach you much about that!! :-laf
The Lilja barrels are kinda iffy.... I've never shot out any Lilja barrels in an AR platform, but going off a bolt gun reference, they tend to vary in life for some reason.... I don't know if it's that they are inconsistent in their manufacture, or if it's their material, but I've had some that lasted 1500rnds before starting to fade, and others that lasted up into the 2500 range.... I haven't built any personal AR type guns using the Lilja's.... they only offer a 1:8 twist, and I prefer 1:7.
The Krieger's last. I've only had one that went away I've used, and that one had over 5,000 rounds of DOD MK262 fired through it. Not that it didn't function, it just wasn't as accurate. Typically, I see those guys shooting service rifle change them out every two years, usually with around 4-5000 rounds through them. If they get a real hummer, they'll take it off when they practice and have others for practice sessions....
The Daniel Defense barrels are made by two mfgs... one is hammer forged mediocracy, the other is button rifled. I'm not a fan of hammer forgings, as I'm sure you're tired of hearing....
All of them are marked... if you look on the barrel, they'll be marked "DD HF ........ " HF or BS for hammer forge or button swage, with caliber and date of mfg following afterwards......
Criterion barrels look promising. I've been going to order one to try, but with other offerings....
I'm not sold on chrome linings, yet, but the theory seems solid, and they've been used quite a bit over the years.... anyone else have experience with them after 2,000 rounds or so?
