So did you actually TEST your ABS unit as described int he video??
Yes, I tested both ports. The piston on both moved at least 3/4". I'm assuming both cavities had to fill with fluid as the pedal moved close to the floor before I would get any braking action.
Sounds like there is air, somewhere in there?
Master Cylinder I replaced* today... to no avail, but o well, this isn't the most expensive part.
Bench bleeded of course prior to install.
The ABS isn't actively interfere with the brake, it's a passive problem.
Switching it off doesn't change the behavior.
And because of the electronic brake distribution of the Gen3 it can't be taken out just like in the old ones.
And actually I like that added safety, ABS saved me more then once from crashing in my wilder years.
*Just because of the maybe factor.
I'm out, because the master cylinder replacement was my next idea. Except for possibly worn rubber brake lines.
The problem is that nobody wants to tell me if he's able to push his pedal to the floor with let's say 150lbs of pressure applied to it.
Like I said, I push it with a raising force to a certain point like it should be - and from there on it can be pushed down with very much the same force.
I found only ONE single post in a forum where a guy said that he can do the very same.
@Ozymandias , are you looking for someone to test a 2004.5 year model truck, or would a 2002 second generation truck do?None, still haven't found someone that is willing to walk out to his truck and push his pedal down as hard as he can.
Anyway, for what it's worth, the brake pedal on my truck only travels 3 to 4 inches maximum (no where near the floor) whether or not the engine is running or the engine is off and the the brake pedal has been pressed several times to bleed off the hydroboost accumulator. All tests done with about 150 pounds of foot pressure as you asked.
- John
Engine on, pump pedal three times, pedal goes to the floor with pretty light pressure.
Hi Ozy. Just read this thread. I got a 2004.5
Engine off, pump the pedal 3 times, pedal goes down about 2-3", rock solid. 150 lbs pressure, not moving.
ZF pump, rebuilt brake booster unit.
