sohcahtoa
Needing new brake pads. I want OEM or Better.
Exhaust brake operation
Almost. Lol
Never fall in front of or directly behind a horse if you can avoid it. So I was a little behind and to the right
Now, using the Ram Console lid as a guide to Some Old Horse came A-Hoppin' Through Our Alley formulae, compute the angle of most painful impact , least painful impact and your impact. Assuming you were gyrating in a horizontal freeform, compute the difference of the angle of departure and angle of ground contact. Hint: Hourly drift rate = 15 times the sine of the local latitude.:)
My ram console lid underbelly doesn't have Sohcahtoa.
Easily solved. Just print the pictures from Post #1 and tape it to the underside of your console lid. Problem solved! :D NOTE: The ruler scale will not be too accurate unless you use the Some Old Horse Came A-Hoppin' Through Our Alley formulae to correct the angular capture. Ain't I just smart (alecky)?;):p
You inngahnears are wierd......
Just sayin'.
HEY!!!! :eek: I resemble that remark! ;):p Worked with quite a few of them inngahnears, correcting the errors of their ways. But sir. Since you retained the old analog switches with latching coils in the new digital system, could it be the reverse 1,700+ volt spike when de-energizing the coil is causing the fried microchips? Zener diode anyone?
