Patriot,
I didn't mean to sound negative in my previous post and it really boils down to your needs. If you have great exposure, and only interested in supplementing your ac (or daytime usage) it might make a lot of sense. If you are interested in storing power for night time usage or cloudy days, then it really gets tough to make the numbers work. Some houses don't have a choice of being on the grid, so wind power, solar power, diesel generator power all looks attractive.
Insualtion is probably your best starting point. 60% of heat loss/absorption usually occurs through the roof. I rebuilt a small cabin on my property and insulated the crud out of it. I even have a double layer roof with rigid foam and an air gap. That place almost stays constant temperature all day long. It has a small ac unit and heating unit just to get the temperature to where you want it. I never noticed a change in my home PG&E bill from when I turned the cabin power back on.
At home, I run as much natural gas as possible. At my other home, heating (forced air and water heater) is all run on diesel. Which until recently, was very cost effective (still better than propane).
