Here is one that has me wondering... . You have a 100w solar set connected to a battery bank (size not necessary) and a 300w inverter. You connect a 300wHr load, is there a 200wHr drain on the batteries?
Is the solar low volt input, nearly 1 for 1 to the 120v inverter output, or is there some huge loss in the voltage being stepped up.
Another example with no batteries connected... a 100w solar set connected directally to a 300w inverter... would you only get say 99 watts of 120v output???
