I've been having Intermittent Starting issues for 2 weeks now.....
Known:
> I've have a new 1125CCA Deka Battery.
> Clean Terminals
> Confirmed Ground
> Continuity run on all wires/Good
> New Super Contacts/Plunger Kit Installed.
> Good Clutch Interupt Switch
"Larry B" suggested that I jump the sarter using the Old Screwdriver Trick next time it didn't start. I just did that w/ the help of a friend and it didn't start.
Procedure:
Ignition Switch on in "RUN" Position
Starter Relay 'clicks'
Placed (1) screwdriver on small, solenoid post
Placed (2) screwdriver on large, main Positive (+) side Post on Starter
Then... ... .
Touched the screwdriver shafts together as a 'circuit/short'.
Result:
1st attempt: No Spark
2nd attempt: Weak Spark/ No Rotation of Starter
3rd attempt: Strong Spark/No Rotation of Starter
4th attempt: Whacked Starter/Strong Spark/Starter turned over.
Question:
Starter/solenoid (Super Contacts installed)???
OR
Ignition Switch???
(Note: Starter has 280,000 mile on it)
Advice welcomed..... I'm frustrated
KEENO
Known:
> Clean Terminals
> Confirmed Ground
Procedure:
Then... ... .
Result:
Question:
OR
Ignition Switch???
KEENO
