First question,
What is an acceptable amount of current draw from the battery from the dash clock and radio memory?
I measured . 012 amps draw inline with the battery cable when I installed a new battery last night.
Second question,
My 83 Crew Cab has factory cruise control. The cruise can be turned on without the key in the ignition switch. Its time to dive under the dash now and check this out.
Anyone have a factory manual for sale for a 1983 W350? Or any reviews on a good aftermarket shop manual that has a wiring diagram in it?
Any of you other first gen's able to turn the cruise on without the key in the ignition?
I would think the key would have to be in the run position for the cruise to even have a power feed available.
Thanks for the feedback.
Paul
1983 1 ton Crew Cab 4WD that needs a Cummins soon
South Burbs Chicago, Illinois
Second question,
Paul
