Some more improvments to my trailer
Wrangler HT
Bumper pull VS 5th wheel safety.
Here are some more improvments to my Raptor trailer.
BTW this is my trailer
I bought the Air-Tabs recently and I have had them on another trailer and I do think they help on the stability especially in a cross-wind. The MPG savings are small unless you do 500 miles a day then there might be some... . So here is the good side in the light... I have a row on each side and on the top... The tabs stuck to the rubber roof, just have to get it really clean...
This is a 14 LED Light that I bought at www.ledtrailerlight.com There are 3 facing at a 45 deg angle to the front and 3 to the rear and the rest is a cluster in the middle. Very bright and almost able to see during the day.
This is a 60 LED 61/2" Oval I bought at a truck stop and the bracket I bought on E-bay (4 of them) These are way bright... . No trouble seeing them...
This is a mid-trailer marker light and Turnsignal I again bought at a truck stop. Also helps in the number of side markers I have... .
The next things I did I don't have pics of them but I got 4... 6-volt golf-cart batteries and hooked them... I have also a 2000 watt inverter if I don't want to crank the gen for a small a/c device... . To charge those up, I have 3 Solar Panels totaling 200 watts.
Think I am about done..... Some of you might have seen the Slide out Awnings I bought...
This Awning has a arm that pulls down when the slide-out is out to make a window awning.
This is a new awning that when it extends, it makes a tent to keep from pooling water.
Whew..... Bombing is expensive!!
Nice looking trailer! How much does it weigh? One of these days I want to get a toyhauler, but my G2 isn't rated for the bigger ones. I know it will pull some of them, but just don't want to take the chance on an overweight ticket!
How much?
iiiiiiiit's heavy... . sorta... ... ok is 15K fully loaded... . uggh.
I bought the Roadmaster suspension from Mr. Bob... That added alot of weight carr. ability... and I am getting 19. 5" tires and 12 ply Michelin tires rated at 4080#/tire.
this trailer is more big than heavy... . It has 6 wheels for the toy carrying but I needed the spring for the pin weight... .
Great post:D Where did you get the awnings from? How does your trailer feel when you tow it behind you truck? I heard sometimes the triple axles tow a little better then a tandum. Great work on your 5th wheel :)
Awnings are Carefree of colorado ... . The pop-up tent one is a new model.
Tows great!! ... not much weight push or anything... . 3 axles on a long trailer just makes sense. my 6 tires are rated for 15,500# ... loaded they are 12,000# on D rated 15" tires
