I might be mistaken, but I thought a fueling box will give upwards of 100 RWHP on a dyno??
justinp20012500 said:Would you test the redline without the mad ecm??? I am thinking of buying one, but with those dyno results I am having second thoughts...
I guess I need to get back on my dyno and do some more testing without the fueling box on... .
justinp20012500 said:I was going to to ditch my old three wire Blue Box and pick up one of those redline boxes. But from what I have seen on dyno is that the edge drag comp will make almost 125 RWHP.
Thats a huge increase. What were your final dyno numbers???RDLeader said:Those are awesome injector only numbers!! Give us some details please.
Justin, FWIW, my drag comp made 166hp at 36psi. The twins help that though.
Roman
KatDiesel said:Is the truck an HO? If so that easily explain the "low" gain of the fueling box.
dlange said:I will be making a dyno run very soon with some of JRS injectors and am planning on about the same #'s. Keep up the good work Ray. Some people dont beleive anything unless they see it. It will also be injectors only with some of JRs toys. Keep up the good work JR and Ray!!
