someone tell me a little about water methanol???
Odd idle issue
I ran a snow performance stage 2 kit on my 1st gen. It worked great with 285,000 on the clock. I talked to the owner of snow performace, he explained everything to me in great detail about the kit and what it does. Windshield washer fluid works just fine. I mixed my coolant with the real stuff 50% methanol 50% water it worked better than the washer fluid, but more expensive. He wanted to know everthing about my truck. After telling him about it he told me exactly what kit and what pressure to run it at. It was on time! Water/meth injection should not be used for towing what so ever. Severe detonation can occur if it is not activated at WOT. He told me to run my hobbs switch at 20 psi. so thats exactly what I did. Low egts. and a real kick in the ***, 3-4 tenths off of the quarter mile et. Want even a little more, dump ice water in it and let it eat!!
so what would you suggest I run in the snow performance stage 3 kit???washer fluid or 50/50 water methanol
Water/meth is PERFECT for towing, bad info there bud.
From Snow's website
http://www.snowperformance.net/news_item.php?prk=7
New Stage-3 Water/methanol Injection System for Diesel Towing/RV
New Boost Cooler® Diesel kit gives 100+ lb/ft Torque increase, 250°f decrease in Exhaust Gas Temps, and better fuel economy!
Snow Performance has developed a new Stage-3 Diesel Boost Cooler® water/methanol injection system for towing/RV diesels. 100+lb/ft torque increases and better fuel economy have been consistently demonstrated. Just as important, over 200°f reductions in exhaust gas temps are common so full power can be utilized for long periods of time such as towing a load up a long grade. Designed for towing, and power, unlike other power adders, it really gives the best of both worlds – big power and cooler combustion. In the words of one satisfied customer, “ now I can tow my trailer 20 miles/hr faster up the steepest grades with cooler EGT’s”. Better yet, this is all accomplished with a fluid that costs less than $1 a gallon!
The Stage-3 Diesel kit features a new Digital Variable Controller with a 2d map programmed into it’s microprocessor that takes both boost and exhaust gas temps into account in regulating injection. The net effect is smooth power in all engine load states with no combustion quench resulting in a true turn-on-and-forget system.
The controller is dash mounted and includes read-outs for boost, exhaust gas temp, and pump output for full visibility. This feature precludes the need for boost and EGT gauges. This provides for a $200-$300 savings if these were to be purchased separately.
Designed as a chemical intercooler for turbo-diesel applications for increased air density and power, the Boost Cooler® also conditions combustion so more fuel and boost can be utilized safely. Methanol acts as an additional fuel source and water cools combustion as evidenced by cooler exhaust gas temperatures. The key is atomization and by injecting at over 200psi through a nozzle that spins the fluid supersonically before forcing it through a venturi-shaped orifice, cooling and power are unparalleled. In the words of Steve Estrada at SuperFlow Dyno Corp. : “the Boost Cooler® by Snow Performance showed more horsepower per dollar than anything we’ve ever tested”.
The Boost Cooler® has received much press recently in diesels as two world records were recently set. In Sept. ’04, Greg Hogue set the diesel truck world record in the quarter mile at 8. 54 seconds using the boost Cooler®. In Nov. ’04, Scott Bentz and his Boost Cooler® equipped Rocky Mountain Cummins Diesel Dragster set the overall quarter mile diesel world record with a time of 7. 98 seconds!! Although applicable to any diesel, the Dodge 5. 9 Cummins, Ford Powerstroke®, and the GM Duramax® have become popular applications.
Priced at just $769, the Stage-3 Diesel kit includes a 150+ psi high volume pump, new 2d mapped Digital Variable Controller that puts just the right injection quantity in under all conditions, specially designed 2-stage nozzles, and all the necessary parts to install on a diesel for an easy installation. The kit can be used on 100-1000hp/ 5-150psig boost applications. Installation takes just 3-4 hours.
BAD FOR TOWING?
I hope not. I have a stage II system sitting on my bench waiting to be installed, and I bought it JUST for towing. I tow really heavy, and with either the TST or Smarty, I have cancel my cruise control up any kind of real grade, due to excessive EGTs. I am hoping that with water/meth, I can let the motor work and pull the hill with the cruise control. I don't run that fast (67 mph), but I have to slow down to about 55 going up even modest hills with the Smarty on 3, or TST on 2. Either way, too much heat. I'll install this Friday and post results next Monday. I've got a 500 mile run pulling about 22,000 pounds with some pretty fair hills. I should know soon enough how it works.
stage 3 snow performance kit
From Snow's website
I am thinking about getting a stage 3 snow performance kit from a guy to put on my 03,what would you recommend I run through it,washer fluid or 50/50 water & methanol,and how much a gallon price whys are we looking for the methanol????
I would go by the manufacturers recommendations, and search around here for people actually running it.
Sorry guys you are right it will most definately lower your egts and give you more power. I am speaking from experience with my 1st gen truck. I will be putting on a snow performance on my 06 in the future. I have on accident activated my stage 2 before at part throttle, it detonated real bad. I'm sure the newer stuff from snow is awesome.
