Read up on a few sound proofing projects. was wondering if anyone had any real # readings in DBA before I go through and redo mine.
I currently have 74 DBA at 65mph and was wanting to reduce that by soundproofing the cab.
if you have done anything and don't have before readings, please post the readings on your finished product.
Please post idle and at cruising speed inside the cab.
If you have done exterior/engine compartment please post these results as well.
If no one has these numbers I will do the project and take results.
Planning project with use of some lead, Mass loaded vinly, butyl asphalt(dynomat/ or seal and peel) and some foam.
