2nd Gen Non-Engine/Transmission sound proofing results
Engine/Transmission (1994 - 1998) hard to start
Engine/Transmission (1998.5 - 2002) Any GOOD Alaska shops??
I also recommend elemental designs for dynomat type stuff. They offered a 10% discount if you join a toyota forum. Dynomat has nothing on lead. ED recommended not using butylashpalt with the lead, but to use neoprene or foam. dynomat is a "mass loader" and mostly changes resonance due to increased mass. It does not "block" sound like lead.
I was going to try some "mass loaded Vinyl" as it is designed to have the same sound blocking properties of lead. Probably would have been easier than pounding lead to fit with a rubber mallet.
I have a 2 db drop. but I have a tire that is wearing funny and makes a lot of noise going down the road.
