South Bend clutch
Dyno Run's
Shocks
mine showed up today!! it's being installed on monday and i'll let you know. i got the feramic eth clutch.
jim
2001 eth, ez box, dd2's
My Ram Pics
bbomb I am currently working with SouthBend on there latest version clutch for the 5 speed I will let you know how it works out. There 6 speed clutches work very well so I expect the best for the 5 speed as well.
1996 4x4 3500 4. 10 5spd, Diesel Dynamics stage 3 injectors, #5 TST plate, Govoner spring kit, Ported Head, ATS manifold Jet-Hot coated, 16cm2 housing Jet-hot coated with 4" Jardine exhaust, Cummins exhaust brake, US Gear overdrive, Grover air horns and Mag-Hytec rearend cover. Special thanks to Piers and BD Performance.
I have there HP clutch I my truck and really like it. There is a slight chatter starting off in 2nd but in the 3 weeks I have had it in I have gotten used to it and can take off 95% of the time w/o any chatter. It holds all the power I'm making, but the tires don't #ad
There method of centering the pressure plate is well thought out.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, 2 Electric Fans, One inside/ One out front, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
[This message has been edited by drawson (edited 03-29-2001). ]
need input on south bend clutch's. I have to upgrade, and was thinking about a south bend. all view's appreciated. both pro and con. keep on trucking. charles
96-3500 slt driftwood 5 speed 3:54 tst#11 straight exhaust BD exhaust brake EGT&boost gauges KN-0880 15k reese hitch 78 gal. aux tank DD stage 11 injectors s. t. improved 4500 tran. charles
BPINE,
Can you explain the difference between the SB and Joe's clutch?
David
PS: Leaving this d@mn snow tomorrow for your part of the country, maybe see some of you all!! #ad
thanks to all you guy's for your help. calling monday to order. sounds like just what i want and need. keep on trucking charles
My South Bend clutch came last Thursday. It's the cermamic puck one that is rated for 425 HP on the 5 speed transmission. I will be getting it installed on Monday the 9th. Well keep you informed.
<font color=blue>"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, HOT Power Edge, Bully Dog Stage III injectors, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), Bar II Brush Guard with KC Daylighters and Fog lights, Ultra-lite guages with blue bulbs. </font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9265455&f=0" TARGET=_blank><font color=red>New Pictures of my "White Obsession" and Dyno Run</A></font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9815423" TARGET=_blank><font color=green>BD Dyno Days 10/28/00</A></font>
<font color=purple>
NRA Life Member! (Need to protect our rights and FREEDOM!!)<font size=-2>
[This message has been edited by BIG BOB (edited 04-02-2001). ]
alright guys I asked something to a wise man not long ago, he was giving me a ride halfway home when I had tcase failure, I had read a article in a 4wd mag about a monster chevy 4x4 with a 5 discs clutch in it. Why cant we stick to what we absolutely know works, spreading surfase load with more serface area and make a 3 disc clutch. Put springs on them in different radious' so you guys believe in needing springs are happy. Why dont we use what works? I hope this eventually leads to better products. #ad
96 4x4, 3. 54 posi, 6. 5"lift, 35" bfg m/t's and 35x14. 5x16. 5 boggers,dual stabalizers, aluminium wheels, sport headlights,billet grill, K/N 0880, NOS, Performance Diesel LPG, BD Pulling/Competition fuel injection pump,370hp marine injectors, ported head, Hx40 w/ 16cm2, 4" exhaust w/ 2 chamber Flomaster, BD copetition auto transmission and torque converter, Kenwood sterio System, Westach 60lb boost/ egt guage with warning light,aluminium bed rail covers,chrome diff covers, 5 foot traction bars,
475hp and 1050lb of torque on #2
530hp and 1140 with bullydog lpg maxed(only 55hp)
590hp and 1200 with lpg and nos
all done in 5th gear with 35's.
have a great day.
Adam
Adam has a good idea , a dual disc clutch will work good for you guys.
I dont know about a 3 disc. Maybe you standard boys can help me out a little bit,
It still seems that some automatic guys out there that think that they can add a mystery switch or torqueloc and try hard or full throttle accelerations without doing any transmission or tc damage.
Now the standard transmission has 4 times the cluth surface than the aftermarket tc, now if you guys can slip yours at approx 275hp, what hope does the automatic guy have ?
Maybe you guys could point that out to the automatic guys the next time you see a thread on mystery switches and torque loc.
Bill Kondolay
Diesel Transmission Technology
Hey Bill you ask what hope do the automatic guys have, I say YOU are the hope now hurry up and make it perfect. lol keep up the good work Bill.
In the case of us Manual guys Southbend is our hope.
Adam I'm just not sure there is enough room in there for all those disks without major modification. Have no fear I have confidence Peter at Southbend will figure it out.
David I'm not sure I am qualified to answer all the differences between Joe's clutch and the Southbend but we will talk about it this weekend if you make it to the SUNNY State.
There would never be room in there for three discs. The only way to have two discs (i. e. McCleod)is to remove the center damping springs and cut a step into the flywheel, leaving no cushion for the diesel "kickback" and causing aggressive idle chatter and eventual syncro shock failure for the load pullers. The only way around that would be a deeper clutch bell housing, shorter driveshaft (or two for 4x4's), modified shifters (L type), and extended electrical and vacuum looms. The next step would be to figure out how to incorporate a pull type release mechanism, as you would never get it into gear without a clutch brake. Cost; around $4500. I checked it all out. Went with Southbend instead... T
South Bend clutch # is MU1938CON-FE... Peter said thats its smooth, and will hold alot of tq? He said that with my PM3 and the DD'II that i will soon add, it will hold up, and then some? What does everyone think about this? If anyone has any interest in this let me know. What do you think about running the DD III's and the PM3. I was told it would eat turbo chargers? Anyone running this setup? Even better... anyone have the PM3, DDIII's, and this Southbend clutch? Let me know guys. . thanks.
Mike
99 4x4 ext cab. TST Pm3, 5 spd, 3. 55's, k&n filter. 33. 5 12. 50 16. 5 Firestones, Flares, Rims, Tool box, bed rail covers, Light Driftwood.
