Peter, Other than posting here, I don't know how to "THANK YOU"!
As I had posted before, Peter sent me one of his "NEW" MU 0090 OFE clutches, "FREE"! It's rated at 450+ HP!
I replace the MU 0087 con B, the original clutch I got from South Bend. There was nothing wrong with it, it had worked flawlessly.
After the installation, I could not get the truck into gear without shutting the engine off. Clutch was releasing right on the floor, truck would move forward with clutch pedal pushed all the way to the floor. After much thought, I remembered that I had BOMBed the slave cylinder with the 1/2 ton slave cylinder from Napa (p/n 360-051, larger diameter), to reduce the pedal pressure of the MU 0087 con B clutch, here is the post:
https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=17829&highlight=Slave+Cylinder
I realized that with the bigger slave cylinder, I was not getting the throw I needed. I replaced the 360-051 cylinder with the stock cylinder (Napa p/n 360-085). In Napa's catalog it says this slave cylinder is only for the gas motors, their book is wrong, the 360-085 is also for our 1999 thru 2001, 2500 and 3500 trucks. After installation the clutch works GREAT! Pedal pressure is about stock or maybe a little less, it starts to engage about half way out and is fully engaged by about 3/4 of the way out.
ATTENTION!
If you have BOMBed your clutch with the 360-051 slave cylinder from Napa, you will need to go back to the stock cylinder (360-085 from Napa) for use with this clutch (MU 0090 OFE).
SOUTH BEND ROCKS!! PETER YOU GUYS ARE FANTASTIC!
OH! I almost forgot NO CHATTER! This clutch is really smooth. If I didn't know, I would think it was the stock clutch!
ATTENTION!
