SPA Gauge programming (HELP!)
Lets see your truck pics :)
Extended Cab SWB Stability
DG 111, EGT/Boost. Lost the instructions-- got the over-temp set, now I can't figure out how to program the overboost. What is EoT? At? Cal? Need a rundown on the various settings for the 111. TIA
Remember that when making any changes to the parameters you must shut the power off to the gauge after each change then turn power back on while holding the red button down. Then by pressing the red button momentarily scroll to the appropriate menu item.
Bl=backlight on or off
rt
PE=reset peaks To reset peaks go to PE and hold button down for two seconds it will go to next menu item
Pr=zero pressure to set zero pressure hold for two seconds which should be done after install
At=set average time routine hold button two seconds this will show the amount of time that the gauge is averaging the reading over from 1/10th of a second to 19 seconds to change momemtarily hold red button it will scroll upwards until 19 then start over at . 1
tb=turbo boost set point for turbo boost model press and hold red button 2 seconds current set point will show, to change push red button momentarily to increment up one number at a time. This will be the setting that the warning light comes on at.
all of the ones that start with E you can skip they are for external switching functions. If needed let me know and I can look those up too.
ot=overtemp set point routine to set over temperature point same as above press and hold 2 seconds to show current value then press red button momentarily to increment it upwards will go to 1990 then start over at 0. This is will be the setting that the warning light comes on at.
thr=thermocouple on or off you want this on for the egt gauge
Lb=low battery point sets a warning light for low battery conditions. As above press and hold for 2 seconds to show current value then press momentarily to change
Uni=set units for pressure display as above press and hold to see value, press momentarily to change. if you change this you have to go back and reset "tb" as it resets it to zero. choices are for this setting kg/cm2, psi or bar. Psi is the most common way of expressing boost pressure. (at least here)
dEg=set degrees for temp display same as Uni except for degrees or centigrade if changed must reset "ot"
rAn=set the gauge to the pressure renge of the sensor used If you have not changed the sensor type you do not need to change this. It allows you to use several diferent sensor types but it should be set to 16
CAL= for engineering access only (code protected)
Seems the spacing has changed from what I typed to what it wanted too sorry hope it isn't to confusing.
Hope this helps
Barry
