BTighe said:just wondering how accurate they are compared to an anolog(sp?) gauge. i like the setup but i want to make sure there good enough.
pwerwagn said:I have a question about the digital boost gauge.
When you are on it hard, how can you read the boost? does it change so fast when accelerating that it jumps 10psi at a time or something? I guess the same goes with EGT, Does it climb so fast that sometimes you cant tell what you are at?
--Jeff
Matt400 said:One thing nice about the EGT gauge is it can double as a a cool-down devise with a selectable temperature. MCrossley figured out that circuit.
Here is a thread with a diagram-
https://www.turbodieselregister.com/forums/showthread.php?t=124981
prestonmck said:My boost will sometimes read a negative number and i'll have to re-calibrate it to show 0 psi at idle.
DHayden said:Mine also show's -1 to -2, I always thought it was normal because in a gas engine at idle their is actually a vacum. Diesel's may not be the same but I can't see why they wouldnt be, correct me if I'm wrong so I know.
JR2 said:SPA's will read neg press (vaccum).
The SPA's also have a memory that holds the peak values in them. So you can see the max numbers at the push of a button.
I rezero my SPA's on a regular basis. Seems to be temp dependen. I see -1 or -2 all the time. Its real easy to zero them out. The newer units seem to hold zero better than the old ones.
