SPA Thermocouple...
Tire pressure
Speedometer Off
Well, I got my SPA gauges installed, and they work great. My only complaint is the connectors on the EGT probe. Very hokey design, looks weak and not durable. #ad
So I have decided to use a different thermocouple. I tried the Auto-Meter #5249, but will not work because it is a grounded thermocouple. SPA requires the use of a type K ungrounded thermocouple. So here's my question... Is the ISSPRO thermoucouple grounded or not? I emailed them a few days ago, and have not yet gotten a response.
For those of you with the SPA gauges, are you using the SPA thermocouple? If not, which one are you using?
Thanks in advance! #ad
BOMBED
<body bgcolor="#FFFFFF">
<font color="#000080" size="2" face="Tahoma">
Evan A. Beck "NW PUNK"
Prez, NW BOMBers
</font></p>
<font color="#800040" size="2" face="Tahoma">
'01 2500HD 4x2 QC, 139" WB, 6-speed, ETH, SLT... yadda yadda yadda... K&N, 3" "PIPE BOMB", 6-way turn signal conversion, aux. backup lights, Line-X, Mopar rubber mats, Cummins badging, SPA Technique boost & pyro gauges. 5,250 miles since 4/26/00! Look for me on AOL as “Beck2500!”
</font></p>
<font color="#0000FF" size="2" face="Tahoma">
<marquee> #ad
Check out NW PUNK for more info! #ad
</marquee>
</font></p>
Hey Punk... Mike C. and HVAC just left my house aprox 20 min ago... It's about 3 hr drive for them home. . [longer as mike just called to say HVAC just had a flat on his new tire and no spare... In Sonora on a monday pre holiday 4:30 pm,,,good luck]. . my point is they arn't around to respond... hope someone else has them. .
Gary
There is a excellant local source for made to order thermocouples. check it out www.eustispyrocom.com . You name it they will make it. located in crowded Bellevue, WA
Tell them Bob Wagner sent ya
[This message has been edited by Heaterexpert (edited 07-03-2000). ]
I will be installing my IISPRO TC today or tomorrow on the SPA gauge. I'll let you know if it has a problem.
If you are talking about the yellow blade connectors as cheesy, those are industry standard connectors for thermocouples.
I went with the IISPRO TC as I did not like the thickness of the one's SPA sourced.
Good find HEATER EXPERT, I wish I found you when I was scrambling around for the larger TC.
David
Evan, the thermocouple for my VDO gauge looks like it is ungrounded. Kind of a pain to get into it with a meter to check but a grounded thermocouple would short out one of the leads and cause innaccuracy. Also, the VDO gauge uses 12V battery to power the gauge circuitry. This would require a floating thermocouple. Summit Racing and egauges sell it. The number is 323-890.
Glen Eaton
2001 2500QC SLT LB 5sp 4x4 Garnet, Line-X, Steel GemTop, Karry boat loader, VDO gauges
Hey Evan which thermo couple do you have, the 1/16 or the 1/8. The 1/8 should be just fine we use that same k type thermocouple at work in are burn boxes 24 hrs a day and they seem to work fine. Also the fans seem to suck up everything and they rattle like a diesel most of the time.
[This message has been edited by BPINE (edited 07-05-2000). ]
hey David, call me, I have the new thicker TC's that are stronger than the first ones out from SPA
TAZ... 2001 2500 SLT+ 4X4 Auto ETC Cummins, LSD 3. 54,Quad Cab, Long Bed, Agate Leather, White/Driftwood Exterior, Sliding rear window, Camper Special Group, Towing Group, Cab clearance lights, Diesel Dynamics Stage-3's, DD Boost Module,SPA-Technique Digital Dual Gauges (Pyro/Boost, Trans pressure/temp) Aux. Backup lamps. BNM 5th Wheel Hitch, Additional Body Molding on Bed.
2000 32' Aljo Triple Slide 5th Wheel.
http://www.ramtaz. 20m.com
Add on's to come: Exhaust Brake, Torq-Loc, Line-X bed-liner, and any other Ram Runner required modification...
EVAN,
Bad news, the IISPRO tc does not work... I get a steady 32F regardless of engine condition. I will look for a meter to ohm out the SPA TC to case.
Now I must find a bushing to go from the large hole I have for the traditional TC that does not work for me.
It does work in my test gauge, so I guess that is how i will travel this time (until I hook up with MCrossley for the right TC)
David
Found the parts I needed to get SPA's TC to work in my truck. Yahoo, finally I see temp on the gauge!! Works great!! #ad
No if fixing my clutch was this easy. . #ad
David,
Thanks for the info! #ad
Bummer the ISSPRO one doesn't work, it looks like a fine unit. I think I will just get some shrink wrap and cover those yellow connectors. *LOL* They may be industry standard, but they sure do look cheesy! #ad
BOMBED
Prez, NW BOMBers
</font></p>
</font></p>
<marquee> #ad
</marquee>
</font></p>
Hey Evan I have been putting black shrink wrap over the yellow connector if nothing else to hold it together properly. The connector is just a bad color not quality.
MCrossley,
Thx for sending the new style TC to my sister's in GF. Will make the rest of the trip all that much better!
[This message has been edited by David_VT (edited 07-09-2000). ]
