Have a '98.5 Quad Cab with 5 speed manual with about 175,000 miles. Dropped the spare tire today to do tire rotation and it was rough and hard. When got done, noticed that the piece holding the spare tire up had a hole in one side due to rust and just looked like it would fall apart if hit a half decent pot hole. What has worked for freeing up the bolts to remove this? Have time to soak with some sort of penetrant before more destructive methods are used. Any one know where can get a replacement winch, other than Dodge, if they even carry it. Does the bed need to be removed to get the bolts out if they are able to be removed using a ratchet or wrench? Any suggestions for a protective coating when get a new one? Know that this is under the bed but would like to put something on the new one though. Instead of replacing might cut the rusted piece off but do not know the best way to attach something that will be as strong as factory.
