so after great thought on weather to spend the $$$$ on the new intercooler i was a buyer. so was the purchase worth the money? the truck is the 98 12 valve it has all in the sig plus s&b intake, plate 1/8 less than half way, screw all the way out, 34 12 tires and new 4. 10 gears,air intake horn. here is what i have noticed so far.
not towing just driving
half my smoke disappeared. wow (this is just a guess but i can see threw the smoke now and not before, (black out).
before intercooler max egt would be about 1400 as high as i could make it go.
after intercooler max egt was 1250 as high as i could make it go
down the road on flat ground would run 1000 at 75 down interstate
down the road on flat ground now runs 750 at 75 down interstate
spool up was definitely a noticeable gain and overall driveability was improved
some will say i had boost leaks before and that is why the gain. well i thought of that too. so i did a pressure test (not just air but with soap and water also) before install (no leaks). i have not pressure tested new unit but will after a few days of driving.
did it add horsepower by the seat of my pants test, yes but anytime you spend that much money on something it always drives better lol. i have not had it dyno'd yet but will try to.
overall i say it is the best mod for the guy looking to lower egts and help a turbo spool. would i buy this for a stock truck, heck no i would go buy a plate or turbo first. if you have some fuel and air upgrades done this is worth the money.
is spearco better than other brands that are cheaper? i don't know but the overall fit and finish was very nice. only one problem with the unit was the lower passenger side boot. it did not fit quite right and felt that it would blow off way to easy. fix was a new boot about 1. 5 inches longer. i feel this could be due to my aftermarket turbo and manifold. the only other intercooler i can compare is my city diesel and the bd (bd was horrible) unit that was on my 06 and that is a totally different truck but overall the spearco was much nicer than both. the polished down tubes are a nice eye candy bonus for the money spent and look great.
would i spend the money again? yes and yes again!!! i want to do some tow testing but i was to lazy this weekend. i will tow next week to a new town and will post here again for the results of the tow test. hope all this helps for those wondering if you should upgrade the intercooler. if you have any questions or want to slam me have at it but i am sold on the upgrade and would recommend it to anyone with a truck that has at least a plate and turbo upgrade (mabe just a plate).
