I know Ford uses a close version of the same Dana 80 as is in the Dodge trucks, and need to know if Ford also uses the same 9224 DC spec LSD differential lube we do, along with the recommended friction modifier.
I need to drain and refill my differential, and probably can get what I need at the local NAPA store, but the stuff from Ford might be cheaper and easier, if it's the proper stuff for the DC Dana application...
